7MGTE AC Compressor help
raven
8
Atlanta
jetjock;1345680 said:
The item in circled in blue is the AC clutch relay. Says so right above it. Located under the fuse box, as if the connector (circled in red) and wire that leads to the compressor...
Located UNDER the fusebox. Of course it is. The only place that lead will reach that I didn't even think to look in. Sheesh.
Thanks jetjock
