mrnickleye said:Can't PROPERLY be done, but hey, you can turbo anything !!
Search out some threads for 7mge to 7mgte.
suprabad said:The only difference between a gte and an mge block is oil squirters for the pistons and domed lower compression forged pistons. That's it! And if you talk to someone who really knows they'll tell you the oil squirters suck! All's they really accomplish IMHO is to lower your already low oil pressure.
So don't believe this shit about 7mge's not being suitable for turbo applications.:nono:
shaeff said:a little mis info here. i happen to like the oil squirters. my belief is that if you want higher oil pressure, get rid of the stock oil filter mount on the GTE's. it sucks, and oil cooling based on pressure is ridiculous. change that for a spin on adapter from an N/A block using a sandwich adaptor and a thermostatically controlled oil cooler and call it a day.
benefits include: better oil cooling (based on temp, not pressure), and increased oil pressure because the stock filter mount is damn restrictive. another alternative is shimming the oil pump. they dont only starve us of oil pressure, they also lower the temperature of the pistons by constantly spraying them with oil to cool them down.
now, cooler pistons lowers the chances of detonation. there's a benefit right there!
as for turbo'd 7MGE's. i'd like to do it one day, or change out my turbo pistons for N/A pistons from my old motor. high compression turbo motors are wicked street machines!
also, stock 7MGTE pistons are NOT forged. damn, i wish they were!
-shaeff
Exactly right.The only people I know who think a 7mge doesn't make a good turbo conversion are people who haven't done it or haven't done it correctly.
suprabad said:Shaeff- I think your wrong to characterize what I said as misinfo.
While it may be your opinion (and others) that the oil squirters are the greatest thing ever, there are also plenty of people who don't think much of them. You must know plenty of people who don't think the benefits of oil squirters are worth the side affect, (lower oil pressure), especially with so many people using synthetic oils I just don't think they are necessary. And no matter how you try to gloss it over they lower the oil pressure, period.
I misspoke on the "forged" part of the piston description (please find it in your heart to forgive me) but they are aluminum and lower compression.
So c'mon shaeff be fair, you know as well as anybody that the stuff you call misinfo is a matter of opinion.
crazystifler86 said:also instead of changing pistons i thought u could just get a thicker headgasket to lower the compression more
p5150 said:Actually, it is misinfo. The oil squirters have a spring loaded check valve and will only open at higher rpm's/psi. At idle and lower rpms they remain closed and have no effect on oil pressure.
suprabad said:And who do you know that drives their Supra at low rpm's?
I guess what your saying here is that the oil squirters only lower oil pressure at high rpm's...excellent...seems to me high rpm's would be the last place you would want lower oil pressure.
