7mge ?'s
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
i just recently got my 7m na running and it starts fine but when you try to drive it it sputters badly and when you are in neutral and try to give it steady gas it will rev to about 2k then cut out really bad and drop back to about 1k then it will be ok until it gets up to 2k again. any suggestions. i know the ks needs rewiring but is there anything else i should check? vac leak,tps,timing anything?:1zhelp:
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
its throwing the ks code i know it code use being rewired but would it cause it to run this bad? i dont know if it could be the firing order or not it starts perfect then when you give it gas it asks dumb...
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
my car did the same thing, except it wouldnt do it until about a minute into driving the car, when it would cut, i had a bad 02 and a bad CPS tho, would those have contributed to the engine cut?
dirtlord420
just here
Aug 1, 2005
371
tn
some times i forget to plug my afm back in and it will start then kinda run. one time it was leaking and it ran like crap. could check for leaks.
