7MGE Knock Sensor
dasz33
20
Denver CO
Is the NA knock sensors the same as the turbo knock sensor?
Can they be repaired? I pulled the green connector and wire out of the block and the plastic glued to the metal came with it. The metal part that screws into the block is still in the block.
Anyone have an extra NA sensor in Denver, or can ship to 80030?
Thanks
Doug
supramacist
1,501
The Grassy Knole
You can buy one from the dealer.
They are under 200 bucks.
Did you break the connector from the wiring harness???
If so you can order that from the dealership as well.
You don't need a new knock sensor, so my bad.
It sounds like you are in the same boat as I am with this sensor.
dasz33
20
Denver CO
The metal screw in part is still in the block. But the green plastic that is attached broke off when I was trying to disconnect it. The green plastic part is still attached to the green plug of the wiring harness.
DaSuprawolf
Im SICK of N/A
Dec 29, 2005
456
ChicagoLand
if the plug on the ks is broke, you'll need a new one.....
and the turbo or N/A are same sensors. you could get one here from somebody for cheap, trust me.
supramacist
1,501
The Grassy Knole
Ya but he'll want a new ks.
Dude there is a sticky that may be worth your read.
And the plug for the knock sensor.
They guys at toyota never officially figured that out.
I had to call a dealer ship in tennessee to get confirmation.
edit: my bad I'll hook you up with a link to the forum it is in via pm.
shaeff
Kurt is FTMFW x2!!!!
10
Around
wow.
turbo and N/A knock sensors are interchangable.
if you broke the actual KS (knock sensor), buy one used. many toyotas use the same one our cars do. go to a junkyard and score one for $10.
you should just do a full rewire anyway.
don't mess with old connectors. get a brand new one from the dealer. (about $8) it's P/N 8221989103
-shaeff
