7mge egr valve the same as 7mgte?
rwdanthony
146
San Diego
i know the modulator is different, but what about the egr valve that bolts from the lower intake manifold to the upper intake manifold?
thanks.
Scruggs86.5T
298
Slidell, LA
I used a 7mge on a Jspec 7mtge to pass emmisions. I had swapped out the blown 7mge for a jspec 7mgte and saved the egr valve for when I needed to get emissions done. It bolted up fine and worked for passing emissions. Although I am not sure that they are exactly the same in how they are designed or not, and if the epc shows different part numbers then most likely they are. I wouldn't use a 7mge egr on a 7mgte long term though, just to be safe. Hope that helps some.
