7mGE clutch... clutch master
GE isn't going to even come close to that unless it's boosted the hell out of, so call it a GTE. While they may make a clutch that would hold the power for a W58, the W58 isn't going to take those power levels. Also, they're rated at torque not horsepower.
peter551984
130
Puerto Rico
Ok basically it is a GTE with a w58
---------- Post added at 09:10 PM ---------- Previous post was at 09:07 PM ----------
although the thing is that clutchmaster makes does model FX600 and FX700 that can hold a lot amout of power, and I just call them with the curiosity and they told me that it can take that kind of abuse since they didn't have anyone having any kind of bad experience with the transmission or engine... They even give me prices for the disk in case of replacement...
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
They are probably talking about folks who have added a turbo to the Mk2, or swapped in a GTE engine in the same chassis. There is a LOT less stress there, because the power is moving a much lighter chassis.
peter551984
130
Puerto Rico
ok so basically the problem is the chassi and weight on the car...
---------- Post added at 09:18 PM ---------- Previous post was at 09:18 PM ----------
So basically If I put it on a corolla it will hold...
peter551984
130
Puerto Rico
Maybe that's why they told I can use it but I can't put sliks on it... and basically if I want it for drag maybe not to start really strong... they almost told to use a fx500 that is cheaper and can hold power that is what they told me
---------- Post added at 09:33 PM ---------- Previous post was at 09:24 PM ----------
What's your opinion...
peter551984
130
Puerto Rico
Basically the price for each disk was like 200, and Can even order with them a triple disck set up but they told me that it will be a harder and probably I'll be rolling dices with the trans... What will be better
