7mge and 7mgte
supraman508
496
maryland
what are the differentses in the cylinder heads besides the exhaust valves.I know they are bigger then the ones on the 7mge but is their anything else different cause i want to build a 7mgte and want to know what mod do i need to do with my n/a block cause i was wondering if i need to bore out the cylinders or can i use a n/a block with a gte head?I hope this makes sense.
supraman508
496
maryland
Poodles;1452521 said:
Um... no, heads are the same, only the intake cam is different.
I was thinking of taking my dads 7mgte head and putting it ontop of the n/a block.ofcorse with all the turbo trimings like ecu and harness ect,ect.
turbo feed and drain for block, knock sensors, oil squirters, lower compression pistons...
Lots of differences in the blocks...
