7MGE 02 sensor on a 7mgte
mx83
jzx81
Apr 1, 2007
14
Toronto
i was wondering if its possible to use a 7mge 02 sensor on a 7mgte and have it wired up as a 7mge or vice versa,and wht is the down fall of using a 7mge 02 sensor.
viper92086
932
NJ
im pretty sure u cant do it. the ecu will prolly thro a code since its sensing no heater on the o2. if its a price thing then find a cheap universal screw type on ebay (denso) and get a adapter plate. it should be about 40 bucks
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
^ Correct. There are simple ways around that though. Otherwise it'll work. Kind of. Without a HO2S the engine will take longer to get into closed loop and may fall out of it when exhaust temp is low, say during periods of extended idling. Considering all that it's more trouble than it's worth.
