7M Turbo Head Repair
N
NDBoost
Guest
I noticed before doing my HG a few months ago that my coolant passages had alot of pits and chips in the corners around the passages.
Where are some good vendors for our heads IE: new or rebuilt etc.
johnathan1
Supra =
Aug 19, 2005
5,056
Mine had lots of chips, corrosion, etc, it was actually to the point of coolant leaking into the cylinders because it was soo corroded... When I had my head rebuilt, the machine shop welded the corrosion up for $75, and it looked really good afterward... Haven't had any problems yet.
N
NDBoost
Guest
Interesting im wondering how much they would charge to do a full rebuild. What exactly is entitled in a full rebuild usually?
I imagine im going to need new valve seals and i def am going to need to have the head welded and reground or w/e.
jdub
Feb 10, 2006
10,730
Valley of the Sun
You may be able to remove the pitting when the head is decked...depends on how deep. Just compensate for the thickness removed with a thicker MHG...Cometic will make almost any thinkness you would need.
Head Job:
- Decking (kinda goes unsaid)
- 3 angle valve at minimum
- New seals
- Check valve guides (usually don't have to be replaced)
- Check valve spring compression specs...replace if necessary
- Check cam journals for scoring...may need to be replaced
- Make sure the cam retainers are torqued properly...do a check yourself!
- Optional gasket match port/polish on both the intake & exhaust sides. There is a lot of material removed on the exhaust side when doing this...runs the expense up quite a bit. I'm not a big fan of excessive material removal close it to the valves...blending in from the gasket match with a good polish is good enough on this head for over 500 HP.
N
NDBoost
Guest
Thanks jdub ill run all that stuff by my machine shop today and see what they want to charge me to do cleaning 3 angle valve job seals, and check springs guides and cam journals. and a basic PP
