7M Plug Valley Cover!
N
NDBoost
Guest
Who makes them for the 7M! Ive heard rumors of someone making them, could this be true :icon_conf: :(
im talking about the plug valley cover thats on the 1J :(
N
NDBoost
Guest
i was referring to the cover that the 1J and 2J has, just to help clarify what it is im looking for. suprasport sells em for the 7M aeh? Ill check it out :)
EDIT:
they dont have what im looking for, im looking for a metal piece that actually makes the valve covers look like once piece like the 1J and 2J :)
aye mate
Hiatus over.
Maryland
Never seen one of those either. Are you asking because you have seen one and want one or you think it would be cool if there was something like that?
mkIIIman089
Ohio
Something like that would require you to move the coil packs or at least run different plug wires...
N
NDBoost
Guest
which i already plan on doing this weekend, i remember seeing one on SF but cant find it after searching.
I wonder how hard it would be to machine one :(
for moving the coil packs you invert the plug wire order use cord 1 for 6 etc and mount the coilpack along the firewall
mkIIIman089
Ohio
What do you plan to do with the wiring harness then? It runs right behind the motor along the firewall where I assume you plan to put the coil packs.
N
NDBoost
Guest
there are 2 screw holes already there, a few people have already done this mod and mounted it there. I believe it clears the harness, maybe ill just have someone fab me up a rounded metal piece w/ hollow tubes welded on the bottoms to put some screws down through into the valve covers..
and polish it :)
