I have seen both engines perform. Yet the Ijz is much more work unless importing a car. So from ownership or research what makes one better than the other? (Not specs, just modded hp and torque numbers.)
lifesnotfair said:No matter which one is cheaper, better, whatever... 7M is factory flawed in more than 1 aspect, it seems to me from what I've researched. 1JZ isn't factory flawed at all, kinda. At least you'd have that piece of mind with it.
Swap a 2JZ. *ahem*
