That would probably be your best bet, that's what I plan on doing. The heads are identical except for the cams, just use your turbo cams when doing the changeover, don't forget to shim it! The reason why I say the GE is your best bet is because they are less prone to BHG, so if you get a GE head, your more likely to have one that hasn't BHG'd
