Alright, so bought this 1991 red manual turbo targa top back in July, drove it for 3 months then BHG, I did a LOT of thinking and reading and decided i'd be better off swapping a 1jz.
I pulled the 7m and r154 back in the fall and everything sat in the garage until i got the phone call from Accelerated Performance that the new engine/trans came in (a week ago). So now i'm trying to figure out what to do to this engine before it goes in, what i should replace for maintenance, and what i need to replace for the swap in general, heres what i've come up with.
Would you recommend i do anything else while i have the engine out? should i replace any seals? crank seals while i'm at it? Please let me know if im forgetting anything or if you have any advice! Thank you very much for your input!
Driftmotion:
2jz waterpump
2jz aluminum pulley kit
oil pressure sender adapter hose
1jz power steering pressure hose
mkIII 1jz intercooler kit (for stock twins) 4" core
Toyota parts:
r154 release cylinder boot
pcv hose
coolant return from turbos rubber hose
^i damaged mine on removal^
2jz serpentine belt
1jz timing belt
Other items:
ACT HD full disk clutch
So does this list seem complete? the oil pressure sender hose and PS pressure hose are on the list because i read about needing them in the 1jz swap section, are the driftmotion items the correct ones for the swap? Are there any additional items you think i would need? I already have electric fans from the 7m and i already have the ebay y pipe/down pipe.
This is where i am now, i need to get a 10mm allen wrench to remove the tensioner pulley, then i'll be able to pull the water pump.
Driftmotion:
2jz waterpump
Toyota parts:
pcv hose
2jz serpentine belt
1jz timing belt
Other items:
