7m-gte difference
Evangallion
7
Miami, FL
I am in the process of buying a 7m-gte for my MK3 and noticed there was a difference within years.
apparantly there was one with 230hp @ 5600rpm in the years 1986.5- 1988, and another at 232hp @ 5600rpm the years 1989-1992.
My car is '88 and i can only get my hands on a 1989 GTE. Is there really a difference aside from the extra 2hp?
note:
read this info on the supra wiki.
JDMMA70
2,550
Houston
Thicker casting on the Post89 and Late88 (November 88 and on) blocks. If the motor youre getting is from a very Late89 it could have the 7M crankshaft in it. Other than that the 7M's are identical
pogoism9
1UZ for me!
May 18, 2007
367
fredericksburg, va
you also get an extra bump from 246 lb/ft torque to 254
all in all you probably wont notice much in car difference between the years due to the 89+ running a 3.73 rear vs the 87-88 running a 3.91
but if you are dropping an 89 GTE in an 88 you would probably notice a slight gain.
jdub
Feb 10, 2006
10,730
Valley of the Sun
A lot of the sensor connectors to the main harness are different. Your '88 may not have a BVSV on the thermostat housing.
Exhaust manifolds are different...reinforcement ridges were added on top of the runners on '89+ motors.
There are several head casting differences as the years progressed, with the later versions flowing better stock.
