7M-GE oil capacity?
Backlash2032
1,823
Nebraska
Ive read (and im sure you all know) that you are sopposed to fill the 7M-GTE a quart over full to prevent oil starvation in a long, fast, left (?) turn. Is it the same way with the 7M-GE?
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Yeah you can fill the 7mge one quart over as well, gives you a safety margin and prevents starving the pump under hard braking. Just fill it up until it shows full on the dipstick, then add one full quart. IIRC someone measured the pan and it is plenty deep enough to hold the extra oil without coming close to the crankshaft.
8,898
CyFi6;1733405 said:
How much oil can you fit without the oil sloshing into the crank during normal driving?
You will be able to hear a strange liquid sound. Not rushing liquid sound, but a....blop blop of the crank in the oil. So your answer is a lot.
