7m-ge motor problem w/vid
Lienhop Photo
151
Wilmington NC
I have no idea what is wrong. It runs but god is it rough. I dont know if it is a dealing with the oil or something else. It makes the sound hurd in video but it is the timing belt i believe and it is something othe than that as well. idk if you can hear it but if someon has some advice please let me know.
It can barely build rpms and it shakes a whole lot
http://www.flickr.com/photos/lienhopphotographics/4182654242/
AcIdBuRn02ZTS
227
Indiana
could be cam timing... could be coil pack failure... injector problem?
when is the last time the plugs/wires/cap/rotor have been replaced?
fuel filter?
i'd start with the simple stuff...
2nd.. how many miles does the car have on it? stock timing belt/tensioner?
its fairly easy to check cam timing.... so check that... then if its been a while since its had a good tune up... id suggest starting there since its your cheapest option...
any CEL?
-AcId-
Bootymeat
51
Bev Hills 90210
1st Stop running your engine like that until you get it figured out. Start here.
Simple stuff. Make sure all obvious stuff is in place. Mass air flow plugged in, vacuum pressure normal, plug wires matched right.
Check your engine codes. Here's how.
1. Take a paper clip
2. Open the "Diagnostics" box (Really small located near the battery)
3. Jump terminals "E1" and "TE1"
4. Turn key to "IGN"
5. Watch the blinking (- - - - - (pause) - is a code 51)
6. Research the code and how to solve the problem
Next check your timing. Here's the simplest way to check.
1. Put transmission in neutral, with the parking brake all the way up
2. Take the crank pulley bolt and turn it clockwise until the mark on the crank matches up with the "0" mark
3. Remove the timing cover
4. See if the "l" Matchmark is aligned with the "l" matchmark above it.
5. If not remove timing belt by loosening belt tensioner and moving cam gears to align with the mark.
6. Re-install the timing belt and cover
If none of these work check your fuel pressure. Might be a clog in the filter
benchwarmer
Straight Cougar
Aug 2, 2007
510
Lancaster, CA
Any details on what happened? Have you done anything to it lately, did anyone else drive it or work on it? It looks and sounds like bad timing to me but you haven't given us any background.
Lienhop Photo
151
Wilmington NC
motor is 250k miles timing was staring to get bad then it stopped running right. Burnt a lot of oil and then it just stopped friving. yea it was driven but not after that started
a friend said it ma be coil pack. I will do a tune up on sat and c what can be done after that
Lienhop Photo
151
Wilmington NC
I looked at the box, it has guky shit in it. When I clean it out I will try. Also I dont have a TE1 its TEM?
