We're leaving off from here boys and girls.
http://www.supramania.com/forums/sh...-bust-almost-2-years-in-the-making!!!!!/page3
Done and over with, body work is in progress, full rust removal and a fresh coat of 8G2 dupont 2 stage chromabase is in order. The engine bay has already been coated with POR-15, and the subframe will get the same treatment, sandblasting all the components and going with welded trac bars, and full red poly bushings out back from energy/ronniek.
The 2jz is at the builder's, clevite 77 std bearings, new oil pump, water pump, gasket set, cometic .066'' MHG, new toyota main and rod bolts, ARP head studs, total seal gapless piston rings, pretty much a factory spec rebuild with ARP and MHG up top. Still using the precision 6152s, but ditched the old fuel for a set of 780cc injectors, and an EMS Stinger 4. Here are the pics i have, more to come. Feels good to be back in business.
By supra_villan at 2010-09-15
Uploaded with ImageShack.us
YEEEEEAHHH
More pics coming soon!
YEEEEEAHHH
