6M crank
whenmunkysfly
scratch that...going 2jz
Jun 26, 2006
746
United States
Ok so never really looked at it until now but after building my engine and having it ready to put in i relized that the old crank i have is a 6M crank. my question is do you think its worth it to have it machined. the guy i bought the car from had spon two rod bairings and it damaged the crank but not extremaly bad. so is it worth it to fix the crank or just trash it?
Superjustin13
Supra teacher 101
Apr 4, 2005
331
Idaho
well Used cranks are still used.
Take it to a Machinest and have him look at the damage, might be able to Polish it, or Grind the journals down and get thicker bearings
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
thicker bareing are all wasy not worth the tiem i find there just wekaer and the 7m bottom end is a spinner
Superjustin13
Supra teacher 101
Apr 4, 2005
331
Idaho
eh?
what?? if the machinest has to grind the journals up to be able to use the crank, you'll have to get thicker bearings, the person paying is not really giving up any time putting it back in, just putting thicker bearings in due to the machinst grinding as much as lil off as possible on the crank, then you wont be able to use STD bearings you'd have to get .10 or .20 etc over
jdub
Feb 10, 2006
10,730
Valley of the Sun
Here is the specs on the crank...this will tell you if it's worth turning or not. Note, the amount of material that can be removed is small..as previously noted, a machinist should be able to tell you based on these specs:
http://www.cygnusx1.net/supra/Library/TSRM/MK3/manual.aspx?Section=EM&Page=83
If you have the crank turned, make sure the journals and rod pins are polished. I would also have it balanced...especially a 6M crank.
The 6M crank is lighter, but is not a well balanced as a 7M crank. The difference is in the counter weights on the crank itself...thay were reconfigured on the 7M. IMO, the 7M crank is better to use.
Superjustin13
Supra teacher 101
Apr 4, 2005
331
Idaho
7m Crank is more counter balanced on cylinder number 2&5 which is why the redline is 250 less, not the only reason its lower, but its part of it
depending on what you want to do to your car, use a 6M or 7M crank on what kinda conditions you want
jdub
Feb 10, 2006
10,730
Valley of the Sun
That blue color is on one of the rod pins correct?
Sounds like the heat annealed the steel and compromised the hardened bearing surface. The crank definitely needs to be turned...replaced if the damage is too severe. I'd take a close look at the rod and main bearing cap oil clearances here:
http://www.cygnusx1.net/supra/Library/TSRM/MK3/manual.aspx?Section=EM&Page=68
and here:
http://www.cygnusx1.net/supra/Library/TSRM/MK3/manual.aspx?Section=EM&Page=71
The journals and rod pins should be nitrate hardened IMO. Inspect the caps and rod ends for damage. I'd also have the rod ends inspected to ensure they're concentric and resized to spec.
whenmunkysfly
Jun 26, 2006
746
United States
nope the crank it self is blue from one main bairing up to the rod bairing and then back down to the next main bairing. its blue on the cast surfaces not the flat ones
and here:
jdub
Feb 10, 2006
10,730
Valley of the Sun
Wow...it had to get pretty hot to do that. Find a good machinist, have the crank closely inspected and point that out. I'm not too sure I'd want to use that crank :icon_conf
89turbosupra
163
oxnard
If the casting part is blue form the heat I would not trust it.
Actually its an old hot rod trick to turn your crank to the limit. It reduces bearing speed to you can rev it higher without spinning a bearing. It also frees up some horsepower due to the slower speed and less friction.
whenmunkysfly
Jun 26, 2006
746
United States
that what i was thinking. its pritty bad. when i took this engine apart i looked at how bad this guymessed up the car and the only thing i was thinking is how could someone ever let their car get this bad. huge dent in the oil pan lead to low oil level and he prob. lost oil pressure and didnt know so the bairing almost disapper. but his words where "i pulled over as soon as it started knocking". it almost hurts me to see how he abused my baby.
89turbosupra said:
If the casting part is blue form the heat I would not trust it. Actually its an old hot rod trick to turn your crank to the limit. It reduces bearing speed to you can rev it higher without spinning a bearing. It also frees up some horsepower due to the slower speed and less friction.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
runing bigger bareing is no no but that is just me
as for bluing and truning caps/rod black can tell yae right now that crank will most likly be toast as in my stander's you only cna drive on rod nock for so long tellt eh damge is to big
as or the 6m crank and the 7m crank both do there job well why was the 7m cank made my biggest guess what toyota tryign to make the 7m smoother kidna like the rx7 but it never will be aka filled motor montes and new crank it did make it smoother but really it's 7m not a 1j or 2j
