6M crank or 7M crank?
6m is lighter and the 7m is better balanced.
so you can either balance the 6m which will lighten it a tad more or lighten and re balance the 7m.
HommerSimpson
1,067
New Smyrna Beach Florida
7m is fully counterweighted so its smoother.. but weighs more.. so taking the 7m and having it shaved and rebalanced is the best .. but cost a ton..
so imho eather or stock will work fine.. if you want little more rpm go with the 6m if you want a smoother engine thats easyer on the bottom end go with 7m
SupraJerry
22
Kilgore
CajunKenny;1380748 said:
Toss them both and stick a Chev 350 crank in there. You'll get more compression.
j/k
How do you strech the cheezy (sorry, I meant 'chevy') crank to fit?
It is too short for a 7M block.
If you have personally done that, I for one would love to see pictures.
Now on the 7M vs. 6M,
I just seen a post by IJ a few weeks ago on the subject,
sounds like he has the most experience on this.
hvyman;1381000 said:
^yup.
just take a 6m crank and have it full counter balanced. light and balanced.
7M crank is fully counterweighted.....they're ALL balanced, look at a 6M you'll see missing counterweights on a couple of the throws, to compensate others are larger/longer so it's never going to be as smooth running as a 7M crank.
black89t
boost'en down 101
Oct 27, 2007
951
humboldt, ca
i have a 7m crank motor and a 6m crank motor. the 7m crank motor is what i'm driving now. really the difference in how they drive is hard to even notice...
