I recently bought a built 7mgte supra with a 6776 bolt on ball bearing turbo with a SP built a340 transmission.
What I am trying to figure out is what people are using for higher stall torque converters for the a340 transmissions. Really would like to know if it is possible to get a stock torque converter modified to stall out over 3200-3500+ rpm or so. I am thinking that would be the sweet spot for this turbo and still be very street-able.
Right now my stall speed is 2800-2900rpm and will build about 5psi (wont go any higher) if I really sit on the stall with the ebrake up and brakes down as hard as possible. When I let off the brakes it still feels very laggy and slowly builds boost. I know the turbo is a little large and is part of the problem, but it matches the motor pretty well once into boost.
Any help with this is appreciated, I have been searching around and haven't really heard of anyone re-stalling a stock converter to much over 2800rpm. I am not worried about the street-ability of the stall as I have been in much higher stall cars and it isn't too bad imo, and it isn't going to be driven every single day.
