Thats a great all around blend. Make sure you use some shrink sleeving also. I would make sure you clean both ends with acetone first, put some kester 44flux on the ends and tin them ,(the flux in the solder is for flowing the solder onto the soldering iron not to flux the two parts being joined) then put a little more flux on the both tinned ends and solder them together, let it cool and clean with acetone to remove an excess flux, your soldered joints should be bright and shinny with no granular look to them, slide you shrink sleeving over the tinned connecting and shrink it down. Kester 44 flux in a non-corrosive all around flux, but you still want to remove as much as possible. Im not sure why your asking about submersion but if your shrink sleeved connection is going to be in gasoline you might wanna make sure you use teflon shrink sleeveing and ensure there is no way anything is going to get a chance to rub on anything in the liquid causing a short.
