You will need the slave, crossmember. wing mounts,fly wheel bolts, chutch fork with bolts, and the 2j parts will most likely not work. I just bought all the parts for my swap which I hope to put in this week.
If all of the 5spd parts came out of a 1JZ, then the clutch will not work. You will need a 7MGTE clutch.
You can buy it all and sell what you don't need. Someone will probably buy the clutch, but you can definitely get rid of the bellhousing fairly easily.
