figgie said:
only when under boost
it actually lowers the VE when off boost that when averaged LOWERS the VE of the engine
The turbocharger only hinders the VE when the throttle is at WOT and only for the first part of the RPM Band 600~1800 RPM give or take a few hundred. If the throttle is at any point other than WOT it (the throttle) becomes the greatest obstruction in VE.
If the throttle is at WOT, the turbo is only in the way until it achieves enough momentum to no longer hinder the air flow. This does not mean the point where the turbo produces boost but where it is spinning fast enough to not get in the way. This point is about 1800 RPM’s give or take depending upon your turbo.
Even at this point the engine cannot produce it’s peak VE. It is still down around 30%-50% VE. Generally, the RPM at peak VE coincides with the RPM at the torque peak. So peak VE is still a little ways up the RPM band. So the turbo does not hinder peak VE.
However it looks like your talking about average VE. In which case even a N/A engine only has an average VE of about 60% on a good day. The modern gasoline engine only has a small window for peak VE A smart tuner will adjust his engine components to operate around this point to get the most usable engine performance.
Good tuners don’t care about average VE they want to know what the peak VE is and where in the RPM band it produces it. Then they can adjust for it.
