57trim fuel cut
stevenr816
932
Phoenix,AZ
i searched but the search takes out the word "cut" so i got 1000's of threads
all i want to know is fuel cut lower with a 57trim? i would assume so being a bigger wheel but how low? im hitting it at 10psi and the wastegate is shimmed with 2 washers. stock maf/injectors. 3in exhaust
BrandonW
1,300
N.J.
yes since with the 57 trim you are moving more air and the cut is saving you from going to lean on the stock injectors
rayall01
901
Westfield, ma
I was hitting fuel cut with the stock CT26 and two washer wastegate shims, so yeah it sure seems like you got fuel cut issues. Pull out the shims for now, until you can get the necessary upgrades to support the increased airflow. That's what I had to do. Now my car runs fine, has seven pounds of boost, and no fuel cut. With the 57 trim, you may still get cut, but it will be less severe if you remove the shims.
