560cc injectors
MKIII TURBO60-1
156
Ocala,Fl
im posting this for ppl looking for injectors, i have 560cc evo 9 injectors in my car, they work perfect, cheap way of getting larger injectors, they are low impedance so they drop right in, u just need injector clips which isnt a big deal, so just to inform ppl evo 8 and 9 work i have yet to check the 10 but i know for sure 8 and 9 both come with 560cc injectors stock and they usually sell for around 100 bucks a set so get two sets and u will have 2 extra for whatever
joel903
314
Conover,NC
this is awesome news, i've been wanting some 550cc injectors for a long time. So if i get the injectors and get some clips then pretty much they're plug-in-play?
Hmong_1G
Name the Place and time.
Dec 31, 2008
280
California
It is said that the EVO 8 and 9 injector ratings aren't accurate. At 35-40psi FP they flow close to 580cc or 600cc if I remember. They are a common cheap replacement in the DSM world but when compensating with a chip, most had to raise the cc programed by at least 10%-15%.
I could be wrong, but they flow around 560-600cc at 35-40psi FP.
koldfire08
139
Las Vegas
Im curious still, still is boggling my mind, i have a Lex AFM sitting around, but i assume i also need 550cc injectors for them both to perform right?
Would i have to do anything else i.e. tuning or FP unit?
PM response would be kickass!
Kevin
7mgte -> 7mgte swap done.
Apr 20, 2009
865
Windsor Ontario Canada
maybe some tunig with a piggyback and a wideband
johnnyddn
56
Las Vegas
oldsking;1534979 said:
Does anoyone know the part number to theses Evo injectors? Alvin you might know haha
Part number on the side of these injectors is MDL560P.
---------- Post added at 11:22 AM ---------- Previous post was at 11:20 AM ----------
The car will run just fine with the Lex AFM and 560cc Injectors, no piggy back needed.
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,777
9
Long Island, Ny
A PM response would not be kickass, as it would not help anyone other then yourself.
A fuel pressure regulator such as the Aeromotive piece is always good to have for added flexibility to overall tuning. An SAFC or equivalent wouldn't hurt either as the 550-lex AFM swap runs very rich. Compound that with under rated injectors as was mentioned here and you may need to lower fuel pressure a few PSI or pull out some fuel with the SAFC.
87mk111
Metal Head
Sep 29, 2009
481
akron/canton, ohio
Just to help me clear up my newbness, whic Rx7's had teh 550's, there's a junkyard about 15 minutes awy from me that has 3 rx7s on thier lot that i was gonna pull some parts off of tomorrow and I was really interested in gettin some injectors.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,236
Atlanta
I believe it's the 87-88 turbo model. The car only had 2 injectors each I believe, so you's have to get pretty lucky in that junkyard.
