so i installed 550 injectors and the lex afm. i also have a wideband and safc II.. when i boost in first gear it runs somewhat rich then as it hits higher rpms it leans out. it does this is first and second gear. in 5th gear if im at WOT the wideband shows a flat 10. so its leaning out in lower gears, but rich in higher gears. what would cause this? or what can i do to fix this problem? i have the afm screw in as far as it will go. Also im only boosting around 12-13psi.
