Could not post in the old thread so...
I've received the Ebay's PTE injectors last week. Could not get them installed, because they were not fitting to the rail properly. Here is why:
Stock Injector ,d=10.42mm
Ebay's PTE Injector ,d=10.76mm
Fuel Rail d is in the 10.75 to 10.77 range ,could not get a precise measurment with this tool.
The point is that these injectors appear to be either NOT machined ,OR not machined enought.
I contacted PTE and they said that there should be no problems with fitment issues ,even if the clearance may seem tight. I belive that the OEM injectors are 0.3x mm smaller for a Reason ,not sure what but I'll proably get these machined before I install them.
Moral of the story is, go "Ebay-cheap" - and be prepared to suffer the consequences
