4AGE Oil Cooler/PS Cooler Upgrade
RedComet13
Rock n Rolla
Mar 6, 2008
113
San Antonio, TX
Is anyone Familar With Roughly How Big an 4a Oil Cooler is? (Rows, Size Length, Width, Depth)
Im thinking of a PS cooler project that Would fit Either in the lower radiator area or On custom brackets Behind where the foglights (Should Be!!) Were.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Using the stock 7M oil cooler as a PS cooler is a common practice and works. If the 4AGE cooler is the same size or bigger, it will work fine.
RedComet13
Rock n Rolla
Mar 6, 2008
113
San Antonio, TX
Honestly Im Going off a Recommendation from user: HonestAbe
I gave him an idea of where I wanted my coolers mounted So on/So forth But that Might make just as much sense and I can find one on ebay easy.
RedComet13
Rock n Rolla
Mar 6, 2008
113
San Antonio, TX
I checked Ebay and There alot of Compact coolers that look like they can fit my needs but is there something I should be looking for More specifically?
For Example Would something like this Have any efficiency?
http://cgi.ebay.com/ebaymotors/9-ro...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Would anyone Suggest an upgrade?
Inlet Size/3/4-16 SAE"/AN Size 8/Metal Tube OD: 1/2
Outlet Size/3/4-16 SAE"/AN Size 8/Metal Tube OD: 1/2
1x -4AN Fitting built on flange
:1zhelp:
