I have decided to have legendofaces.com rebuild my engine with their Package 2. It consists of the following:
Clevite 77 Main Bearings
Clevite 77 Rod Bearings
ARP Main Stud Kit
ARP Rod Bolts
Polished Crank
Toyota Piston Rings
Brass Freeze Plug Kit
Fel Pro Gasket Set
ARP Head Stud Kit
Goodyear Timing Belt
Aftermarket Timing Belt Tensioner
Thermostat
High Flow Water pump
Titan Motorsports 1.4mm Metal Head Gasket
Block Cleaning (Baking Process)
Cylinder Honing
Line Bore Block
Block Resurfacing and Lapping
Crank Polishing
Line Bore Rods
Three Angle Valve Job
Cylinder Head Resurfacing and Lapping
This rebuild package is rated at handling 4-500hp. I plan on replacing the CT26 with a SP61GT turbo. My target with the SP61 is 450 crank hp. With that in mind, what supporting mods would you recommend? I'm relatively clueless concerning fuel and engine management. I will be replacing all coolant hoses, and I will replace the radiator with an aftermarket one, just not sure which. I am also considering a FFIM to accommodate a larger intercooler. I already have the ebay recirc ddp from 935, as well as a 3" HKS exhaust. I have a Greddy Profec B2 boost controller, and an Apexi timer.
Thanks for any and all suggestions, and as always, I will include build pics of the entire process.
Ben
ARP Main Stud Kit
ARP Rod Bolts
Polished Crank
Toyota Piston Rings
Fel Pro Gasket Set
ARP Head Stud Kit
Thermostat
Cylinder Honing
Line Bore Block
Crank Polishing
Line Bore Rods
Ben
