4 piston calipers in supra
zoonwen
1JZ Supra
Apr 27, 2005
199
Denton, TX
yes they have, its called the night pager kit. 935 replicated the kit but I'm not sure if it is still available.
MK3.0dudeman
brian L.
Mar 12, 2007
1,628
North Jersey
300zx brakes from Z1 off a TT whole set is like 500$ beans.sorry but you can't beat that now idk how much the brackets is but it's like 200$ thats not a bad set up but if you want to save yourself the trouble just go with ARZ there cheap brand new and work great from what i've heard
bobiseverywhere
bobb'n for money
Montreal
www.bobiseverywhere.com
If your talking about the calipers, i have no idea why you would want a floating caliper still...
http://en.wikipedia.org/wiki/Disc_brake
Calipers
The brake caliper is the assembly which houses the brake pads and pistons. The pistons are usually made of aluminum or chrome-plated iron. There are two types of calipers: floating or fixed. A fixed caliper does not move relative to the disc. It uses one or more pairs of pistons to clamp from each side of the disc, and is more complex and expensive than a floating caliper. A floating caliper (also called a "sliding caliper") moves with respect to the disc; a piston on one side of the disc pushes the inner brake pad until it makes contact with the braking surface, then pulls the caliper body with the outer brake pad so pressure is applied to both sides of the disc.
Floating caliper (single piston) designs are subject to failure due to sticking which can occur due to dirt or corrosion if the vehicle is not operated regularly. This can cause the pad attached to the caliper to rub on the disc when the brake is released. This can reduce fuel effiency and cause excessive wear on the affected pad. Additional heat generated by the constantly rubbing pad can lead to warping of the disc also.
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,778
13
Long Island, Ny
$500 for a set of ZX brakes? im guessing you mean calipers, pads and rotors? only the fronts will work (IIRC) and you cant use the ZX rotors because they wont fit (Also IIRC), you need to use MK4 front rotors or 350Z track rotors (Again IIRC). neither have the right hub bore size so either hub centric rings or grinding the hub are required (Also IIRC).
im going for ARZ's wilwoods when the time comes. cant beat bolt on perfection.
gixxer750
2jzget comingsoon!
Mississippi
I already have 300zx calipers and can get my hands on TT supra rotors for free.... anyone still have some brackets laying around.. 300zx calipers are pretty good.
mkIIIman089
Ohio
Ckanderson said:
^ it isn't?
No, I thought they were too. Unfortunately the rotors are bolted solid to the hats.
I mean, its still probably one of the better kits out there, I was just a little disappointed thats all.
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,778
13
Long Island, Ny
why would you want floating calipers and rotors?
our stock rotors are solid mount...at least mine were. only floating stock was caliper. the willwood kit looks to be fully solid mounted with opposing pistons in the caliper.
Bondango
Supra Specialists Ireland
I run the 300zx Calipers up front with nissan 350z (Track edition in the USA) rotors. The brackets will also allow you to run nissan Skyline r33 and r34 GTR brembos as well as the 350z Track edition brembos as they as use the same bolt offsets as the 300zx calipers :)
Contact group-a-supra on here, re plicated the knightpager kit a while ago, he may have some brackets leftover
mkIIIman089
Ohio
Yes. I don't know why bob thinks they are full floating rotors stock.
Google is your friend on the other question.
