4 electrical problems are any linked?
the1andonly0032
33
Iowa
First, Fog lights do not work and Headlights do. Past owner said they never worked.
Second, Interior lights, only the red lights on the door work, all other are non-responsive even when turning on int. lights with dimmer.
Third, Clock. No display at all.
Fourth,Radio. The past owner had the constant/memory wire hooked up to the ignition power wire so that it only had power once the ignition was turned on, but this caused no memory in the cd player so I rewired the constant memory wire to the memory wire from the car and it blows the engine bay radio fuse as soon as the wires touch.
The 3rd and 4th problem I solved by myself.
Any ideas on Fog lights not working and Dome lights not working?
