4" down pipe/Turbo elbow
suprarich
Guest
Nov 9, 2005
2,187
ohio
sounds like you just need a turbo with a 4" outlet!
No really, your 4 inch pipe would make a good elbowless dp if you fab it up to a weld flange, but after that anythng over 3 inch would be overkill on a ct, as stated above.
ians13
537
Jacksonville, fl
chriso said:
Yeah, 4" is a little overkill. When your're done with it I think you should just send it to me !:naughty:
j/k
after it's done i'll let you guys know how it worked out but christmas is comming and am broke :(
SupraDupra500
195
Terre Haute, Indiana
im doing complete 4" exhaust. Jon @ mdc has an exhaust housing from a Holset HE351C for my HX35. it has a 4" v-band outlet. ive got a 7' length of stainless 4" piping and im just using mild steel elbows from NAPA. going ot coat them after its all done. shoudl be pretty sweet.
i say do the 4" !!!! why not! be loud as hell
-Josh
jamesdem1123
98
Palm Harbor
ive always wanted to run two 2.5 inch angled pipes on either side right below/behind the doors. not sure how the body wor is through there but i bet with enough time money and patience it could be done.
