4:10 Gear Opinions !! o.0
Supra-Man18
357
miami
Has anyone here experienced 4:10 gears.. If so how is the highway cruising ? gas mileage ? daily drivability ? If not what do you recommend ?
tsuper92
supra addict
Apr 7, 2005
1,376
mass
i like it but also run a 275/40-17 out back.with the stock size wheels/tire's it would probably be a little much.
joliroger4
Flying Dutchman Pilot
Apr 4, 2005
264
New Jersey
www.geocities.com
It's the perfect gear for a full weight MKIII ~550whp with raised rev limit on a 26" tire in the 1/4. I'd run it anywhere between 5-600whp. The car will trap anywhere from ~6400-6800 depending on exact weight and horsepower in 4th. If you do a lot of highway, yeah, it isn't quite as pleasant of a ride as the 3.91 or 3.73, but the difference isn't really that great, didn't bother me at all. 4.30 was a little excessive on the highway, but I still didn't really mind as I never really go over 70 on the street. I'd run the 4.30 anywhere from 4-500whp, assuming same weight and tire size as above for ideal 1/4 mile performance. If you aren't a 1/4 mile guy and drive the car a fair amount than you might want to stick with a 3.91. Most guys wouldn't be able to tell the difference between a 3.91 and a 4.10 if you put them in a car on the street and didn't tell them.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
whoudl love a 4.10 but they don't make it so the 3.91 is ncie choice to run to bad there hard to find i swaped one in my car sad part is my speedo is out
i swaped the speedo from the 88 tranny kinda like it is 4.30
cause i think there is missing thooth on the in side of the tranny so it's around that ball park
so now i just going to swap back in the 89 plus gear to se if it help's i kidna don't wana rip apart my trans to swap a gear
Jeff Lange
Administrator
4,919
5
Sunnyvale, CA
jefflange.ca
joliroger4;899199 said:
I know you are the toyota parts guru, but I personally pulled my 3.91 from an 89 car in a yard.
need new tires;899292 said:
i also have pulled a 3:9x from a early 89 auto.
Yes, I've heard things like this before, but not once has anyone ever actually ever posted up any sort of proof, showing an 89 with a 3.91 differential. Every 89 I've seen (including 1st-2nd month production vehicles), has had a 3.73, and all of my documentation shows all 1989's came with 3.73:1 rear ends.
So until anyone posts a picture of a data tag from an 89 with a 3.91 axle code on it. I'm sticking to my guns, haha.
I made an offer of $20 USD about 2 years ago to anyone who could post a picture of an AE86 GT-S with an A/T, nobody ever has. I think this is the first time I've said it for this, but I'll PayPal $20 to anyone who has a picture of an 89 data tag with a 3.91 diff code. ;)
EDIT: It should be mentioned (but I believe it is understood), that this applies to any North-American vehicle.
Jeff
joliroger4
Apr 4, 2005
264
New Jersey
www.geocities.com
You are right, 3.91s have a drive gear with 10 teeth and 3.73s have 11, so you can not just swap the driven gear to correct the speedo. I got my 4.10 from a Torsen and swapped in a US LSD.
Jeff
I'd love to take your money, but the car was crushed over 5 years ago.
SUPRASTEVE
Supra Maniak
Jun 13, 2007
504
So Cal
Jeff
Hmm I got an 89 turbo 5spd this one was made in April of 1989 where can I find the code for the differential.
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
Opinions on 4.10?
Well, highway milage isn't that bad in my car, around 9.5-10l/100km, whatever that works out to in MPG. Cruises a little high for my liking (about 4000 cruising at 140km/h), but gets into boost fast that way.
I break my 285s loose at 100km/h.
I'm considering droping down to a 3.73 or 3.54 just to see how much of a difference it would make.
SUPRASTEVE
Supra Maniak
Jun 13, 2007
504
So Cal
joliroger4;899738 said:
Look either on the firewall or the door jam for the data tag. The axle code will be either G305 or G315. I'm betting 3.73 with that build date.
i'll check right now
mdr40z
arkansas
where might one find a 3.54 gear, I've got a th350 swap that i love except for highway cruising
annoyingrob;899735 said:
Opinions on 4.10?
