350Z calipers
supra8903
512
Latham, NY
I heard that you can put the 350Z track edt. calipers on our ma70s. Is there any truth in that. In addition if true how much would it cost. The track edt. are the brembos, right?
Joseph
souprat
fairfax VA
supra90turbo said:
They are Brembo calipers and yes they should fit. If you have access to a CNC.
woha woha woha. this is the first i have heard of this. what needs CNC machining? can you use stock rotors/lines? do they clear sawblades? do the 350 calipers fit on all 4 corners of the ma70 or is it just the fronts. more info please.
garagefujimoto
Local Tire Destroyer
May 27, 2005
997
Calgary, Alberta, Canada
You will need to machine special caliper adaptation brackets front and rear, and a larger rotor would also be in order. Unless you have a wrecked Z33 it may be cheaper to buy a kit initially designed for a Supra.
KeithH
Portland, OR
I would have to agree with ^^^. You factor in the cost of the used parts and then the cusom work to make them fit and you may have well picked up some even better brake kit that was designed to work on the Supra.
