Doesn't it usually mean that the compressor housing is bigger? If the housing is bigger I would assume that would make more power, being a bigger turbo.
Is that what you meant? Or did you have a specific turbo in mind?
Somtimes I see the same size compressor housing, .60a/r for example, but one has a 3" inlet and the other has a 4" inlet. I've wondered on that same housing would the 4" inlet make more horsepower than the smaller one. I'm sure a .70a/r housing would flow more.
So, by running a 4" intake pipe and 2.5" plumbing with it that would increase peak HP. But would that contribute a little bit to lag? The turbo would have to pressurize more area with the bigger diameter plumbing. Or is that not a factor? When you say ENTIRE system that would include the throttle body and intake ported to match it. Ok, that makes sense.
the 3" in 2" out is the E cover.
the 4" in 2.5" out is the S cover.
the 4" in 3" out is the H cover.
the bigger the cover, the more flow. but it has to be matched to the comp wheel as well as the rest of the setup. i.e. running a 54mm turbo in an E cover then swapping to an S cover will not see gains. but running a 67mm turbo in an E cover then swapping to an S cover you will.
