3" exhaust to 2.5" to 2.25" muffler
Prettyazznouka
75
NYC
Would that really make a difference since I have 3" dp to the cat. I want to cut
off the cat then continue past the y pipe then b4 the muffler(magnaflow) use 2.5" and weld up to the muffler.
Question is, would that really make that much of difference in regards to the turbo and exhaust flow. Or should I get 3" mufflers and go 3" start to finish
Prettyazznouka
75
NYC
I meant 3" dp, 3" mid, 3" x pipe, 3" where resonators are, then before the muffler use 2.5" to weld up
or just get some fleabay 3" mufflers or something
MOON
34
calgary alberta
question..where do you guys get the 3 in, high flo cats from, i am going to get the 3 in downpipe but just wounder about the cat? since i alreaddy have the 3 in cat back, might as well doit all ,, thanks
Prettyazznouka
75
NYC
If your looking to pass emissions with a high flow cat, dont waste your money. If you dont care about that then ebay or hottexhaust.com
