My Brake, Battery and Burnt out back lights, are all on at the same time, This happend all at once as I was driving home from work. I did some research on it and found that other guys had this problem when their alternator was going. I checked my alternator and it wasn't making any charge. I pulled it and it needs new brushes.
My question is: On the shaft of the alternator is there suppose to be groves for the brushes to run in? Mine have about 1mm grove where each brush should go. I can't tell if this is wear or if it was machined in. (See picture)
Any help or at best a picture would be awsome
