Two bolts and it comes out. There is a gasket under it. You'll need to disconnect it at the fuel rail too. Two crush gaskets there. If you're not sure it's working better to test things electrically first. If you just want to clean it you'll have to pull it out and soak the tip in a cleaner. That'll clean the outside and *may* clean the tip but the best thing to do after that is hook a aerosal can of solvent (Berryman's Chemtool works well) to it and connect it to your battery. That way you can flush it and check for a good spray pattern. No sparks, flame, or smoking while doing this or it'll be an occasion to break out the marshmellows.
Just another reason to always run a Top Tier gasoline like Chevron or put a dose of polyether amine based injector cleaner in your tank twice a year. Use polyether amine as it's the only stuff that actually works. Other FI cleaners are little more than weak solvent based snake oils. Polyether amine is found in Techcron Concentrate, (Chevron invented the stuff), Redline SI, BG44k, and Gumout Regane (in the clear bottle).
The manufacture of polyether amines isn't cheap so expect to to pay more than for cheapie FI cleaners but the stuff works. Regane is the best deal at around 6 bucks at Target and some auto stores. It's 30-40% PEA. Try Ebay for BG44k and pay around $11, much less than the $28 or so it usually costs. Then again I've heard BG Products changed it's formula to no longer include PEA so who knows. Regane is the best deal if you don't want to pay for Techron Concentrate. Pass on the Chevron ProGuard, it's a watered down version of Techcron.
