Hey guys im trying to find out more info on the 2nd gen 7mgte motors compared to the 1st gen 7mgte motors. Now as far as im aware from information from "Google" and other supra forums everything is almost the same but the crank is diff on the 1st gen 7m that uses a 6m crank which revs 400 to 600 rpm higher then the 2nd gen 7m and the 2nd gen 7m motor is 2hp higher.
At the moment i have a 1st gen motor with the 7mgte 87-88 ecu yellow plugs & loom , motor is basically getting old and rings are worn. before i buy this 7mgte 92 2nd gen motor (jdm imprted) can i just use my existing loom and ecu or would the 7mgte 87-88 ecu would have negative affect to the 2nd gen 7mgte motor
thanks guys
regards,
thanks guys
regards,
