2jzgtte auto to manual conversion question
Supra89
19
Los angeles california
Can you use a 2jzgtte with auto tranny and auto ecu/harness then use the engine for a manual w58 tranny?? What do i need to make the auto 2jzgtte to make it manual?? And is it hard and expensive.. I saw a 2jz auto for $1500 so i was thingking about it.. Thnx for the help in advance..
Albert
May 13, 2009
1,710
Tempe, AZ
Yes you can use the 2j auto ecu to run manual. By buddy just bought a 2jzgte auto for 1700 then bought a R154 and converted to manual. His is running fine.
To go w58 (which I don't reccomend cause they are weak)
youll need:
w58 to jz bellhousing
flywheel
clutch
pressure plate
w58 driveshaft
lines
slave cylinder.
If your mk3 isn't manual stock you'll also need:
master cylinder
clutch pedal
brake pedal
shifter
etc
