Now I am finally ready to start my 2JZ up, but there is no spark.
I had a weak battery, charging it now...
I have 6-8 volt on the injectors when cranking, and no spark. Im not sure if I have wired the Neutral Start Switch right, could this cause the problem I have?
I have also figured out the i miss one plug near the Ignitor. Two connectors (one big and one with four pins) go to the ignitor and the third has two pins. One is ground and the other is no. 1 injector. What do I do with this connector?
I have checked the wiring for the cam/crank sensors.
Crank sensors measured 1182 and 1193 ohm, but my crank sensor only measured 1121 ohm. Should really be between 1630-2740 ohm? acording to the tsrm.
I hope you guys can help me out here.
