Hello all...I've recently did an aristo 2jz swap in my 89 and have just began to "put my foot in it" but have noticed that it won't boost any more than 2-5 psi. Using starting fluid I've checked for any boost leaks and all hoses and couplers seem to be good and tight. I'm still on stock twins at stock boost also. I can hear the turbo's (or maybe turbo?) spooling and the stock bypass valve goes off in between shift. (no aftermarket one at the moment) I also have two vsv's, which I was told was for the sequential twins, that came broken when the engine arrived. Could this be the issue?? Any help would be appreciated and thanks in advance.
