2jzgte swap issues...
Status
Not open for further replies.
funky_monkey58
Closing in on 200+MPH
Apr 3, 2006
1,307
St.cloud MN
Alright I have the 2jzgte swap into the 87 about finished. It cranks but has no spark. Im using the stock aristo ecu and will be going back over all the wiring later on tonight. IS there anything I should check out for me not getting spark? Ignitor perhaps?
Any help is appreciated.
-Sean
kikwear002
174
Ft myers florida
power to ignitor, check all coils plugged in. Grounds,
I had the same problem i had a few wires backwards from the ignitor to the ecu.
Check fuses and relays too. Good luck
best if you had a wiring diagram and a multi-meter to do this efficently
Satan
Tampa
Wow! Dr Tweak's got some good stuff on his site. Making miracles everyday, huh doc?
Looking good!
funky_monkey58
Apr 3, 2006
1,307
St.cloud MN
Well I checked continuity on all the pins from the ecu to the plugs. Im going to try firing it up again and using a engine diagnostic computer on it to see where my issue is coming from.
Status
