hi everyone, i've done a 2jzge (from a '93 AUDM i believe) swap into my '86 mk3 and thanks to this site haven't had any issues until now, atm all i think is stopping me from completion is wiring >.< i'm trying to use the 2jz harness and ecu due to 7m harness being very old and falling apart
can anyone identify two these plugs? or know where they go?
do these wires coming off the alternator need connecting/will it run without them?
if not where do they go?
these are the connectors for the ecu
i believe the far right plug has the pin for the fuel pump, can anyone confirm this?
i've been unable to find the ecu pinout for this specific ecu so i've been trying to wire everything up by using the pinout for the v6 toyota prado, apparently the ecu's are the same (same plugs/connectors) just with different features (4wd control, etc) however whether the plugs are the same is unknown to me.. if anyone can help it'd be greatly appreciated
