2JZGE SWAP INTO A CRESSIDA IS IT A DIRECT BOLT IN..???
2JZMK2+1
73
st.croix
Found a 2jz GE 5speed for a good price an just wanted to know if it can fit into a 89 on CRESSIDA ,,(direct bolt in)
Also how much power can those 2JZ-GE 5speed hold....????
Thx marvin..
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
those 2jzgte 5 speed are be W58 their same supra non turbo......
anyways... they say the w58 holds about 300-400 horsepower and i dont think the 2jz is a direct bolt-in with the cressida. search how people bolt the 1jz into the cressida and whatever they do you need to do.
2JZMK2+1
73
st.croix
Thanx .....Figured it was a W58..... change of plans....lol...
Ken
350
Houston, TX
you will need motor mount brackets from a JZX81 or JZX90, and if that 2JZGE you're getting has a rear sump oil pan, you will need to swap it out with a front sump pan.
Also if that W58 came out of a MKIV supra, then you're going to have to do something about the shifter. On my friend's cressida we tried swapping out the extension housing from a MK3 W58 but it didn't work out for us, so we ended up using the MK3 W58 transmission with the JZ W58 bellhousing.
soapra
860
VVTi'n, CA
www.kaizenmotorsport.com
100% Right!
DonS1mpson
Black Supramacist.
Mar 19, 2006
674
England!
2JZMK2+1 said:
complete setup motor an trans..... 2JZGE AN W58 TRANNY...
Okay, that's what I thought.
What would have to be done in terms of electronics? I've read in the past that not only is it possible to run a 2JZGE off of the 7MGE ECU and Loom, but it's fairly easy (It's a matter of swapping around a couple of senors to 2JZ ones and getting something to control the fuel, apparently). Any truth behind this?
I have often thought about going 2JZGE as a stop gap for a full blown NA-T setup.
