2JZGE swap into 87 7MGE Supra?
Rob_Supra87
87NAPWR
Aug 3, 2008
278
Millbrae
would a swap be worth it to put a 2JZGE into a 1987 Supra with a 7MGE? I was just curious, also seeing how the NA 2j is probably at least more upgradeable then the 7MGE I was just curious if it was worth it or not if I wanted a cool reliable cruiser car with a bit of power lol
SupraMario
I think it was the google
The Farm
In short yes...We are currently doing a 2jzge swap on my friends 89 NA.
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
you can use a turbo harness and plug almost everything in..
you'll need pre-89 1JZ conversion mounts, or a late 89+ cross member + mounts, but I've seen several running around..
Rob_Supra87
87NAPWR
Aug 3, 2008
278
Millbrae
Interesting, yeah I met a guy with a 2JZ into his MK2 so I was just curious if it was done in MK3's, would a MK3 with a 2JZGE with BPU be able to hold its own well with more modern cars?
A. Jay
Search.
Jun 3, 2009
671
Bay Area, CA
RazoE;1591767 said:
BPU Na-T turbo or I/H/E..?
I'm interested in the potential of this engine, too. How much power could I get na-t with stock compression? If the compression changed over the years, I'd be getting a pre-OBDII engine, so what ever compression those came with is "stock."
Edit: I'd prefer to get a number in bhp. My goal is 280-300, doable with stock internals?
