I would keep 10:1 compression... Especially if you are standalone.
Stock TT pistons have gone 8.8 in the 1/4, they aren't a weak link on a budget. The NA pistons and rods are making what the stock bottom ends (TT and NA) tolerate with the smaller PTE billets. The new units make crazy torque so I figure both pistons/rods are going to be fine, and if you can get E-85 the compression is going to help out tremendously for torque all over.
If you're VVt-i bottom end, then obviously yes switch out.
When going for more than 700 ft./lbs of torque, it's time for a set of Eagles/Scat rods with higher rev limit.
My NA block with 180,000+ miles made 635rwhp in 100 degree temps, and probably more at night... Lasted for more than two years of daily beatings with no problems at that power level.
EDIT: Noticed you are on 850cc injectors, you can max those out on that block with E-85 and not break a sweat. Stock pistons and all with 10:1. The PSI safety on E-85 depends on your turbo, but it's up there well above 36PSI++++. This of course limits reliability over time like any other fuel making big power on a stock 2J, ahem...
