2jzge into mk 3
ecko
9
Tasmania
hi
ive seached every where but couldnt find the exact answer i need
im putting a 2jzge in my 86.5 with 7mge
im going to use the w58
all i need to know is what clutch do i need?1jz 2jz?
what pressure plate etc? any help much appreciated
ecko
9
Tasmania
Bigzavs;1142827 said:
my guess would be that you need a 2jz w58 flywheel and clutch setup, not to mention the bellhousing
i read on the guide you need 1jz flywheel..
i have a adapter already for the bearbox just the clutch im stuck on..
im guessing just a normal 2jzge one but wanna know for sure
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
I'm pretty sure you need the 1JZ flywheel, 1JZ bellhousing, 7MGTE PP.
Driftmotion will definitely be able to help
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
you can't use the 7MGE W58, you must use the 2JZ w58.. which means mounting difficulties and a custom driveshaft. If you still want to do it, which you shouldn't... then you'd need a 2JZGE clutch, flywheel, PP ETC.
If you go R154 you need a turbo driveshaft, 1JZ bellhousing, 1JZ flywheel, 7M clutch/pressure plate (unless going twin disc).
SuperNova
93
Grand Prairie, Texas
You need the 2JZGE to W58 bell housing, 2JZGE flywheel, and 2JZGE Pressure Plate and clutch disc (I've been told a 7MGE disc is the same). This is the setup I am going to use for a while on my 1JZ. The hard part is finding the bell housing, I searced junk yards and had no luck. I went OEM toyota on the flywheel and bell housing (both NA-Mk4).
