bountykilla0118 said:uumm the 2jzGE and 7mgte are the same. You did not read that long response i gave you in another thread.....
However 2jzGTE are different.
antman said:-fuel and a method of controlling that fuel to supply enough for your power needs. On more basic setups I recommend the Emanage blue. Affordable and can tune your car very nicely. Most basic kits can make good power with MKIII Supra Turbo injectors. They are also top feed (but low impedance, need resistor box or inline resistors) and denso style but flow 440cc instead of 330. The Lexus V8 AFM modification is affordable and can make the 440s easily tunable with a simple fuel controller.
Is it just me or is this paragraph stating that 2jz-ge injectors are 330's and not 440's.
88YotaTurbo said:i thought stock sizing for 2jzge engine was 550 my mistake?
