2JZ what size?
bobiseverywhere
bobb'n for money
Montreal
www.bobiseverywhere.com
the 2Jz Uses CT12 Turbos.
The 7M-GTE uses a CT-26
I don't think it would really be worth it unless you used both but that would mean a custom Mani.
Honestly though i think the only thing you would gain from that is an earlier spool up. More low end power but then cap out on what they can flow for the engine.
For the cost of having them and probably having to rebuild them and then the custom mani you are better off upgrading a CT-26 or Buying a Replacment Turbo that will bolt up to all the stock 7M Mani and Down Pipe
theflash083
ua
1_slo_92 said:
What size turbo's do these run? Also any way to make them (or 1) work on a 7m-gte?
sequential twin CT12B turbochargers i dont know that you would want to they are smaller than that the 7m's in sence their are 2 compared to only 1.
Stanzaspeed
2.5 Twin Turbo R
Calgary, AB
the ammount of effort required to make the project work is just not worth it. That is unless you have the time, tools, and material to do this with little overall cost to yourself.
im sure that for the money there are better setups to be had.
